TwinTurbo.NET: Nissan 300ZX forum - Also...the FSM does not show pulling the engine to replace
Zirvana
on August 02, 2006 at 5:51 PM
I once called 5 Nissan Dealers and asked them whether
posted by Zirvana
on August 02, 2006 at 05:23 PM
the turbos. Generally, we like to believe in the FSM.
Questions about a having a shop repair busted turbos
Timmy
15:07:17 08/02/06
IMO...
15:17:09 08/02/06
Turbo replacement only for the $4,100 (n/m)
Timmy
16:25:40 08/02/06
Also the place doing it is Z place in Lauderdale, I have
Timmy
16:31:35 08/02/06
Yes, they probably have the technique for "half assing"
DAYTONAZ
17:28:45 08/02/06
Don't get the impression I'm breaking your cojones
DAYTONAZ
18:04:36 08/02/06
Really!? So let me make sure I understand what you're
DAYTONAZ
17:45:34 08/02/06
New Stock turbos, not re-built but new, I don't want to
Timmy
18:04:22 08/02/06
You don't need to upgrade the ecu for a turbo upgrade
DAYTONAZ
18:21:32 08/02/06
What aftermarket turbo has a 9psi wastegate preset?
ZLover4Life
19:58:05 08/02/06
OK even less $$ for new stockers then $1650 >>
DAYTONAZ
18:31:28 08/02/06
The problem I'm having is if the engine was pulled and turbo
Timmy
19:20:52 08/02/06
Re: Questions about a having a shop repair busted turbos
Kenny
15:24:55 08/02/06
WARNING!! WARNING!! WHoop Whoop WARNING!!
DAYTONAZ
15:50:40 08/02/06
2nd
Pacmanpth
15:54:00 08/02/06
That obnoxious title certainly lends your post credibility. (n/m)
Kenny
15:57:06 08/02/06
I adapted that from the stall warning call outs
DAYTONAZ
17:24:25 08/02/06
Bullseye! This is a big job and its not for some R&R >
BrianTT(TPA,FL)
15:59:24 08/02/06
Go somewhere else. No reputable z shop is not going to pull
MikeVar82
16:14:49 08/02/06
Zirvana
17:23:33 08/02/06
Also...the FSM does not show pulling the engine to replace -
Zirvana
17:51:17 08/02/06
There are many ways to do a job, the recommended way
DAYTONAZ
18:14:13 08/02/06
So the FSM is wrong? Five Dealerships are wrong?
Zirvana
11:55:14 08/03/06
what's your point?
ZLover4Life
19:48:22 08/02/06
What's my point...I'm trying to tell the guy that he does
Zirvana
11:51:13 08/03/06
I'm confused...
ZLover4Life
22:20:59 08/03/06
That's right...that is why I don't claim the knowledge, I
Zirvana
11:53:37 08/03/06
So outside of completely pulling the motor is $4,100 a fair
Timmy
18:06:52 08/02/06
I think its fair if done by a WELL known z shop. >>>
MikeVar82
18:53:34 08/02/06
$4,100 is turbo replacement only, no 60k (n/m)
Timmy
19:23:17 08/02/06
Then its way to much. (n/m)
MikeVar82
19:33:45 08/02/06
2nd, find a new shop (n/m)
10:49:51 08/03/06
repair busted turbos while in car
txq45
18:35:25 08/02/06
I emailed you to see if you might be interested
Z_LiFe
20:23:51 08/02/06
I responded, btw did you know your website doesn't work? (n/m)
Timmy
21:19:49 08/02/06
Hey i can take care of it for you >>>
Rich@RZTperformance.com
21:57:23 08/02/06
Or he can search on here, people like you :) (n/m)
07:15:48 08/03/06
^^^Timmy Definitely the way to go>>>>>>
MikeVar82
09:53:10 08/03/06
